"On Localize Call" without target
- Multiplayer
- Visitor
12 years 4 months ago #126
by Multiplayer
"On Localize Call" without target was created by Multiplayer
Hi
I would like to use the localize scripts "On Localize Call" to call my own script whenever language is changed, since I use none of the pre-implemented components such as NGUI or TextMesh.
But it seems like there is no message sent unless something is selected as a target (other than "none") for the localize script, even if I do not need the script to do anything by itself. Everything works if i simply add a component like GuiText and set it as the target. I can then disable that component and my script gets called anyway. But it would of course be much better if I did not have to do that.
Is there a way to use only the "On Localize Call" without using any other components?
12 years 4 months ago #131
Replied by Frank on topic "On Localize Call" without target
I just added an event that gets called whenever the language is changed. (Version 2.1.0 b3)
There is no longer need to add a Localize component to an object in order receive a call, just register the function that will handle the custom localization.
void Start()
LocalizationManager.OnLocalizeEvent += CustomLocalization;
public static void CustomLocalization()
// This function gets called whenever the language is changed
}Hope that helps,
- Multiplayer
- Visitor
12 years 4 months ago #132
by Multiplayer
Replied by Multiplayer on topic "On Localize Call" without target
Thanks a lot for the quick change, that should do it.
I will send you an email to get access to the newest version.
Time to create page: 0.178 seconds
