Changing Font
12 years 4 months ago - 12 years 4 months ago #123
by SuperBuff
Changing Font was created by SuperBuff
I've added the Localize component to the UILabel, i'm using NGUI, but the secondary tab does not refresh the tab. I cannot change the text AND the font, It seems it's one or the other.
Please advise.
Please advise.
Last edit: 12 years 4 months ago by SuperBuff.
12 years 4 months ago #130
Replied by Frank on topic Changing Font
I have been trying to reproduce that issue, but I haven't been able. I'm assigning fonts and texts without having them override each other.
Are you using the latest version?
Can you list the steps you do to make that bug happen on any of the example scenes?
Thanks a lot,
Thanks a lot,
12 years 4 months ago #156
by SuperBuff
Replied by SuperBuff on topic Changing Font
Hello Frank,
I add the localization component.
The main tab is selected.
I select the term
I then click the secondary tab.
Set it to font
And drag the fonts into the slots.
Then i go back to the main tab and i see that instead of text it says font.
I select the term
Set it to font
12 years 4 months ago - 12 years 4 months ago #157
by SuperBuff
Do i need to add the font name to the sheet or something?
Right... so it seems that was it. I've added terms for every font I use, the english is the name of the font and the Chinese has the Chinese font name.
Strangely enough when running in the editor, Chinese is shown as default. Did i miss something?
Last edit: 12 years 4 months ago by SuperBuff. Reason: more details
12 years 4 months ago #160
The startup Language is selected as follow:
- The first time your game runs it tries to use the language your device/system is using (Application.systemLanguage)
- If can't find it, it then picks the first language in the language's tab on the Source
- That selection is saved to the PlayerPrefs, and from that point on, everytime you run, the game remembers that selection and starts with that language enabled.
So, if you changed the language to Chinese in the game, it will start with Chinese everytime you run the game.
Time to create page: 0.150 seconds
