OnLevelWasLoaded obsolete starting on v5.4.0f1
- Indiefreaks
10 years 3 months ago #1591
by Indiefreaks
OnLevelWasLoaded obsolete starting on v5.4.0f1 was created by Indiefreaks
I just noticed while moving my project to Unity 5.4 that OnLevelWasLoaded is getting obsolete and therefore not suitable for the future of I2 Localization.
The issue is raised on Console with the ResourcesManager singleton script.
The new recommended way to handle this event seems to use the SceneManager.sceneLoaded delegate simply adding the following code to replace the existing code:
Not that urgent but I always like to avoid seeing warnings coming from plugins when I can
private void Awake()
UnityEngine.SceneManagement.SceneManager.sceneLoaded += (scene, loadingMode) => { LocalizationManager.UpdateSources(); };
}Not that urgent but I always like to avoid seeing warnings coming from plugins when I can
10 years 3 months ago #1592
Replied by Frank on topic OnLevelWasLoaded obsolete starting on v5.4.0f1
I'm too an organization freak, so, even when Unity 5.4 is not released yet, I already fixed that warning in one of the latest releases.
Are you in the latest? I have to double check exactly when, but either in 2.6.6 or 2.6.7a1, that warning was fixed.
My advise is to upgrade to the latest, and to the latest 2.6.7 if possible as those add lot of fixes.
The following user(s) said Thank You: Indiefreaks
- Indiefreaks
10 years 3 months ago #1593
by Indiefreaks
Replied by Indiefreaks on topic OnLevelWasLoaded obsolete starting on v5.4.0f1
I am actually using 2.6.6b1 at the moment as I'm updating all my plugins through the asset store as I avoid adding beta plugins to a project unless I really need some blocking issues' fixes.
So unless you tell me that 2.6.7a isn't on a beta stage, I'll stick to this one with my silly little change
10 years 3 months ago #1595
2.6.7 is in beta.
Its fully functional, but I always like to have each version at least 3 weeks in the beta folder for people to try and find any bug before I officially release it.
Said that, 2.6.7a1 has been downloaded 128 times in the last weeks, so it should be fairly stable as there hasn't been much bugs reported.
But, as you said, if you don't need the new features in there, then its safer to keep 2.6.6b1 until I officially release the new one.
2.6.7 is in beta.
Time to create page: 0.236 seconds
