Executing Localize script via script
12 years 4 months ago #97 by Jos
While i can use the GetTermTranslation() method (or the handy ScriptTranslation class) to get run-time content, i can't as simply do the multi-term stuff which Localize gives me. Specifically changing the font & text at the same time on a GUIText (or TextMesh).
We have a dialog system where i can pretty easily add keys for each line of dialog, but that dialog uses a single GUIText (for example). I'd like to be able to reset the "Term" and "SecondaryTerm" of the Localization script component and "rerun" it, so it updates all the items properly.
I'm not sure if simply making RegisterTargets(), EventFindTarget() and OnLocalize() public would do it (OnLocalize() is already public, but it is using cached data).
Any suggestions?
Jos
12 years 4 months ago #98 by Frank
If you have a GUIText object with a Localize component. You could change the Term and SecondaryTerm and then call OnLocalize to update the translation based on the new Terms.
The localize component does cache some of the data it uses, but not the actual Terms and translation. Given that I2 Localization can handle several object types, the RegisterTargets is called initially to detect what object is meant to be localized (i.e. if its Label or a Sprite, or a sound, etc).
You don't need to call RegisterTargets again unless you are actually destroying the GUIText component and creating a new one. But if you are only changing the term or text in the GUIText, then the cached values will be ok as only the reference to the GUIText component is cached as well as the functions that do the translation for that type of object.
So, just change the term and secondaryTerm and call OnLocalize(), that should work fine.
The following user(s) said Thank You: Jos
12 years 4 months ago #100 by Jos
Excellent - i had just tried this out in one of the example scenes. Much better then me having to tweak the code. It is like you had already thought of this use-case! ;)
Thanks for the quick reply,
Jos
Time to create page: 0.188 seconds
