Specified target is being changed by the system
10 years 6 months ago #1437 by grit
Dear Frank,
I am using objects, which have a Tk 2D Sprite component as well as an Audio Source component.
I want to localize the AudioClip in the Audio Source (not the tk2d sprite). Thus I choose "AudioSource" as a target.
The term type is an AudioClip.
This worked fine before with an older version of I2 Localization (2.4.5 f3)
I just updated my whole project (Unity 5.3.4 f1) and along with this also the I2 plugin (to 2.6.5 f5).
Now every time I run the game or only switch between scenes, the target is being switched to 2DToolKit Sprite, and the localization doesn't work any more because of that. The error tells me, that the sprite is not being found in the collection, because of course it is actually an audio clip. The log:
SetSprite - Sprite not found in collection: GameCounting/01_game_counting_1_fr
tk2dBaseSprite:SetSprite(String) (at Assets/Plugins/tk2d/Code/Sprites/tk2dBaseSprite.cs:260)
I2.Loc.Localize:DoLocalize_tk2dBaseSprite(String, String) (at Assets/Plugins/I2/Scripts/Targets/Localize2DToolKit.cs:78)
I2.Loc.Localize:OnLocalize(Boolean) (at Assets/Plugins/I2/Scripts/Localize.cs:169)
I2.Loc.LocalizeInspector:OnDisable() (at Assets/I2/Localization/Scripts/Editor/Inspectors/LocalizeInspector.cs:87)
I am not sure, if I might have messed something up, because in this project I am using UnityScript instead of C#, and because of that, I had to reorganize the folder structure of your plugin a little, see attached screenshot.
Do you have an idea why this is and how to solve this?
Thanks a lot,
Grit.
10 years 6 months ago - 10 years 6 months ago #1441 by Frank
Thanks for reporting this issue!
I just uploaded a new version of the plugin (2.6.6a2) to the beta folder that includes a fix for that.
Last edit: 10 years 6 months ago by Frank.
The following user(s) said Thank You: grit
10 years 6 months ago #1442 by grit
Dear Frank,
thank you very much for the quick fix!
However, where can I find the beta folder? I have no clue. :unsure:
Yours,
Grit.
10 years 6 months ago #1443 by Frank
10 years 6 months ago #1444 by grit
Thank you, Frank!
Now it works again!
You are awesome. :kiss:
Kind regards,
Grit.
Time to create page: 0.139 seconds
