Localization Inspector Window Collapsed
10 years 6 months ago - 10 years 6 months ago #1375
by Romland
Localization Inspector Window Collapsed was created by Romland
Not sure when this happened, but we've been using Unity 5.3.4f1 and during edit mode the localization inspector window becomes collapsed so we can't edit anything. During play mode the inspector window is able to be opened and edited, but of course as soon as we are back into normal edit mode, you can't access the localization inspector window.
Any ideas that may help?
Even creating a prefab during play mode doesn't carry over any information from the inspector window, so we're kind of stuck.
Last edit: 10 years 6 months ago by Romland. Reason: Image added
10 years 6 months ago - 10 years 6 months ago #1376
Replied by Frank on topic Localization Inspector Window Collapsed
Can I get a bit more insight about your issue:
What version of I2 Localization are you using?
Are you seeing any error in the console?
Are you using a languageSource added to a scene gameObject or are you using the I2Languages.prefab?
Do you have more than 1 languageSource?
Does that languageSource have languages?
That should help me understand your issue and help you asap.
EDIT: From your screenshot, if you collapse the Text component by clicking in the arrow next to it. Does the Localize component expands or does it shows the same?
Last edit: 10 years 6 months ago by Frank.
