Using most Recenter Version, problem with \N
- wagenheimer
Topic Author
- Junior Member
10 years 6 months ago #1355
by wagenheimer
Game Developer on www.greensaucegames.com and www.sevensails.com.br
Using most Recenter Version, problem with \N was created by wagenheimer
Using the most recent version, all my \N (Break Line) were converted to \\N and does not works anymore.
How to fix this?
How to fix this?
10 years 6 months ago #1356
Replied by Frank on topic Using most Recenter Version, problem with \N
1- Can you please let me exactly which version of the plugin are you using:
2.6.5 a2 (AssetStore latest)
2.6.5 f1 (Beta folder latest)
Each of them uses a different WebService.
2- Also, are you importing from Google or from a CSV file?
3- when you say it converts \n to \\n, Are you texts written with a "\" and an "n" like "this is a line\n this is another line"
or with a real linebreak like:
"this is a line
"this is a line
- wagenheimer
Topic Author
- Junior Member
10 years 6 months ago #1357
by wagenheimer
Replied by wagenheimer on topic Using most Recenter Version, problem with \N
Import from Google
My Text is this way :
"Level {0}\nStart!"
On I2 prefab it appears correctly! "Level {0}\nStart!"
But in realtime,
It shows me on Console : "Level {0}\nStart!"
But if I add an breakpoint and inspect the Text variable, the Text value is "Level {0}\\nStart!"
I don't know if this is expected! But I'm having problems with LineBreaks not working on TextMeshPro, and I'm not sure if the problem is with I2 or with TextMeshPro.
Any advice?
Import from Google
"Level {0}\nStart!"
But in realtime,
var Text = LocalizationManager.GetTermTranslation("levelstart");
Debug.Log(Text);It shows me on Console : "Level {0}\nStart!"
Any advice?
10 years 6 months ago #1358
If I understood you correctly, what you are describing is the correct behavior.
If in unity or google you type "Level {0}\nStart!", you are not actually typing a line break, instead you are saying that you want the text to show a '\' followed by the letter n.
If you want a break line, then press enter or copy/paste a line break. That makes easy to copy/paste texts and keep the original formatting.
What you see in the plugin inspector is exactly what you will see in TextMeshPro, "\n" will not be translated to a new line character.
And when you use the debugger, monobehavior and visual studio preview will show you the '\' as \\ to make you realize that \n is not a new line character but two separated characters.
A quick fix is to either remove the \n in I2L and press enter to make a real new line character. Then export back to Google.
If you look at the example scenes, there a few labels showing texts with several lines.
Hope that helps, but if you need it, I can post some screenshots of how it should look in google spreadsheet, unity and in-game.
wagenheimer wrote: My Text is this way :
"Level {0}\nStart!"
But in realtime,var Text = LocalizationManager.GetTermTranslation("levelstart"); Debug.Log(Text);
Any advice?
- wagenheimer
Topic Author
- Junior Member
10 years 6 months ago #1359
by wagenheimer
Thanks for the answer Frank!
I was using "Real Line Breaks" before, but on some cases I need to convert the translation to CSV and use the CSV_Import Feature and it seems CSV does not like "real line breakes".
But thanks, I will make some more tests here.
- wagenheimer
Topic Author
- Junior Member
10 years 6 months ago - 10 years 6 months ago #1360
by wagenheimer
I2 is converting it to "\\n" somehow in runtime... I expect the exact same string is returned from my tag, but not, the string is really returning with \\n.
The problem is here! Create a new term by example : Level {0}\n Start!1What you see in the plugin inspector is exactly what you will see in TextMeshPro, "\n" will not be translated to a new line character.
Last edit: 10 years 6 months ago by wagenheimer.
Time to create page: 0.919 seconds
