Center justified text changes to left justified
- MooseMouse
10 years 10 months ago #1144
by MooseMouse
Center justified text changes to left justified was created by MooseMouse
I just purchased the latest version of I2 localization, and I'm using it with NGUI 3.9.4b. Localizing changes my UILabels, which are set to "center" alignment", to "left" alignment. Is there a way to make them stay center aligned?
10 years 10 months ago #1145
Replied by Frank on topic Center justified text changes to left justified
The alignment reverting to Left was fixed in version 2.6.2 a1 (which is now in the AssetStore), Can you double check that you got that version installed?
If you still see this issue after updating the plugin, please, let me know and I will correct it asap.
BTW, if you send me the invoice number I can give you access to the beta folder where you could download the latest release (which is still pending review in the Assetstore: v2.6.2 b1)
- MooseMouse
10 years 10 months ago #1146
by MooseMouse
Replied by MooseMouse on topic Center justified text changes to left justified
Yes I just downloaded it today from the Asset Store. It is v2.6.2 a1, and it is still happening.
I will pm my invoice number to you.
- MooseMouse
10 years 10 months ago #1147
by MooseMouse
I can't figure out how to PM on this forum so I just sent you and email.
Shawn
Shawn
10 years 10 months ago #1148
yep, that will work better!
10 years 10 months ago #1151
I double checked the NGUI integration and there was still a problem for some labels that caused the alignment to revert.
I added a fix for that to the new version (2.6.2 b2).
Now you don't have to unselect the "Adjust Alignment" checkbox as you explained in your email.
The following user(s) said Thank You: MooseMouse
