Build Script with Selected Terms fails
12 years 7 months ago #63 by hex
The Build Script with Selected Terms command fails if plugin is moved in another folder inside Assets. I think the path to ScriptLocalization.cs is hardcoded?
12 years 7 months ago - 12 years 7 months ago #64 by hex
I have changed line 11 in LocalizationEditor_Tools_Script.cs
#region Variables
const string ScriptLocalizationFileName = "/<FOLDER_NAME>/I2/Localization/Scripts/ScriptLocalization.cs";
#endregion
It works now. Still this should be fixed.
Last edit: 12 years 7 months ago by hex.
12 years 7 months ago #65 by Frank
You are right. Allowing to select where the plugin is located will be a great thing to add.
I will include that tweak in the plugin!
Furthermore, I can also detect where the ScriptLocalization.cs file is located by automatically searching in the project folder structure and use that by default.
Thanks for the suggestion!
Time to create page: 0.214 seconds
