Term changed does not work in editor
10 years 11 months ago #1104
by yuewah
Term changed does not work in editor was created by yuewah
I am using I2 2.6.0f1 + Unity 5.2.x
In Editor mode, when I change the Term in Localize Inspector, the translation below is updated, however, when I switch between the language, the textmesh text is updated using the old translation.
10 years 11 months ago #1106
by yuewah
Replied by yuewah on topic Term changed does not work in editor
I fixed myself, but not sure if it is good or not.
LocalizeInspector.cs
mNewKeyName = Term = mTermsArray[newIndex];
mLocalize.SetTerm (mNewKeyName); <-- added.
10 years 10 months ago #1116
by yuewah
Is the fix not have problem ?
10 years 10 months ago #1117
Replied by Frank on topic Term changed does not work in editor
I just verified the change and it works fine.
The SetTerm will update the cached Term and SecondaryTerm so that enables previewing the language changes using the new term.
I have included that change in the next release of the plugin,
Thanks a lot for the workaround!
10 years 10 months ago #1121
by yuewah
sorry, the workaround is not work if FinalTerm and SecondaryTerm are public.
LocalizeInspector.cs, comment out the following code.
mProp_mTerm.stringValue = Key;
mProp_mTermSecondary.stringValue = Key;
Time to create page: 0.190 seconds
