LanguageSource location?
10 years 10 months ago #1096 by yuewah
In latest version, LanguageSource can be either in resources folder or scene, can it be placed in other location that is loaded using AssetDatabase.LoadAssetAtPath
Therefore, the LanguageSource will not be included in the final built and having the editor feature.
10 years 10 months ago #1097 by Frank
Replied by Frank on topic LanguageSource location?
As you said, LanguageSources can be placed in the Resource folder and as far as they are in the LocalizationManager.GlobalLanguageSources array, they will be loaded.
LanguageSources can also be placed in the Scene, and as far as they are instantiated, they will add them self to the LocalizationManager.
However, if you manually use AssetDatabase.LoadAssetAtPath, to load a source, then you have to call
LocalizationManager.AddSource( source ) so that it get used and initialized. And given that AssetDatabase is an Editor only class, that will only work when in the Editor and the LanguageSource will not be included in the build as its not referenced.
Time to create page: 0.256 seconds
