Numbers and <brackets> scrambled by I2 Component
11 years 1 month ago #991 by ColtonH
I am posting this as a new topic, as it seems to be a unique problem for I2 Localization
I am having problems with the Localize Component scrambling the text of a Text component. (not GUI Text, but the new UI Text component in Unity)
Specifically, numbers are turned into random symbols and brackets ( < > ) are reversed. I am trying to implement Rich Text using I2 Localization so this completely destroys any tags I am entering.
In the inspector for my text object (containing a text component and a localize component) I can see the formatted rich text correctly in the localize component:
<size=40><b>Title 01</b></size>
<size=36>Name <i>object 56</i></size>
When I copy and paste this text directly into the text component it works perfectly, but when the localization script sets the text it scrambles the numbers and symbols giving me this:
>size=٤٠<>b<Title ٠١>/b<>/size<
>i<object ٥٦>/i<>/size< >size=٣٦<Name
I am using a basic font (HelveticaNeue-Light) and other fonts such as Arial have the same problem.
I am assuming this is a problem with I2Localize as directly copy and pasting the text works fine.
I have updated to the recent 2.6 version from the Asset Store but am still experiencing this problem.
Here is an example of numbers being scrambled without formatting:
Text in I2 Localization Component:
sample number: 56754
Text Set in Text Component:
٥٦٧٥٤ sample number:
This kind of seems like a big problem... I am surprised that there are not other topics with this issue-
Thanks for the help!
11 years 1 month ago #992 by Frank
Sorry for the delay.
I have been hold up solving a couple support emails that have taken longer than expected. But I will check this up as soon as I get back.
Just to be sure: Which version of unity are you running (4.6, 5.1, 5.2?)
11 years 1 month ago #993 by ColtonH
no problem, thanks for getting back to me on this!
I am using Unity 5.1.1 f1 (64 bit)
11 years 1 month ago - 11 years 1 month ago #995 by Frank
I tried a few things but I was unable to reproduce your issue.
I created an example scene similar to the uGUI Localization scene.
And created a new term in the I2Languages.prefab.
Then I referenced that term in one Text (the unity new UI).
As you can see in the screenshot, the plugin was working as expected.
I also tried exporting the I2Languages.prefab to a CSV file and importing again.
Also, exporting/importing to a Google Spreadsheet.
In both tests I got the correct string.
Can you please send me a list of steps that make the bug happen for you?
Edit:
Also, It looks like your string is been parsed for RTL. Is that happening for a RTL language or for English as well?
Try checking the Ignore Right To Left Language checkbox to see if that's the issue.
Last edit: 11 years 1 month ago by Frank.
Time to create page: 0.161 seconds
