DoLocalize_UILabel called twice ... sometimes
11 years 2 months ago #880 by cedtat
I need to implement a functionnality that will zoom size of fonts in my app.
I have made a quick modification in I2 in DoLocalize_UILabel to update font size when localisation is done (I use NGUI).
I could have used the callback but I was lazy and didn't want to add a callback for all the labels in my app :)
I have noticed that some labels were not properly resized and when logging information, I found out that the method mention above was called twice. I was wondering if it was an issue or if it supposed to work this way ?!
Cédric
11 years 2 months ago - 11 years 2 months ago #881 by Frank
The OnLocalize function was indeed been called a couple times at startup.
Version 2.6.0 b1 fixed a few of those, but I just verified another case that made the OnLocalize been called twice.
I added a new fix for that so that it never gets called twice :-)
Those changes are in version 2.6.0 b2 which can be downloaded from the beta community folder.
You will be pleased to know that Global Callbacks is one of the features I have for 2.7.0. I already did part of the integration, but I have to change the UI a bit to allow setting that in the editor.
Last edit: 11 years 2 months ago by Frank.
Time to create page: 0.208 seconds
