How to add a country/language code
11 years 3 months ago #848
by cedtat
How to add a country/language code was created by cedtat
I was wondering if there was a way to add a new language/country code.
I have to create an english localization for LEBANON (which is different from other english localizations). It is not a standard code but it will be great if I can handle that by creating a "en-LB" code.
Is there a way to add it in I2 ?
Thank you,
Cédric
Thank you,
Cédric
11 years 3 months ago #850
Replied by Frank on topic How to add a country/language code
You can add any name directly in the Language Source.
However if you want to create a new language code, you will need to add a new line in one of the scripts.
Nonetheless its really easy:
Just open Assets\I2\Localization\Scripts\Google\GoogleLanguages.cs
At the end, there is an array with all the ISO languages, codes and the code used as fallback in Google Translator.
To add Lebanon specialization to english, just add the definition at line 219.
It should look like:
After the script gets compiled, the code and language will show in the Language Source popups.
{"English/Caribbean", new LanguageCodeDef(){Code="en-CB", GoogleCode="en"}},
{"English/Ireland", new LanguageCodeDef(){Code="en-IE", GoogleCode="en"}},
{"English/Jamaica", new LanguageCodeDef(){Code="en-JM", GoogleCode="en"}},
{"English/New Zealand", new LanguageCodeDef(){Code="en-NZ", GoogleCode="en"}},
{"English/Lebanon, new LanguageCodeDef(){Code="en-LB", GoogleCode="en"}},
{"English/Republic of the Philippines", new LanguageCodeDef(){Code="en-PH", GoogleCode="en"}},
{"English/South Africa",new LanguageCodeDef(){Code="en-ZA", GoogleCode="en"}},After the script gets compiled, the code and language will show in the Language Source popups.
11 years 3 months ago #851
by cedtat
Replied by cedtat on topic How to add a country/language code
Thank you Frank,
This is exactly what I was looking for
Time to create page: 0.178 seconds
