add/remove terms through code
11 years 4 months ago #843 by Deadcow
Is there a way to add/remove terms through code? I've got my own dialogue system, it allows to add/remove dialogs and add/remove messages in this dialogs through inspector of object, which will cause dialog to open on interaction, and each message is currently refers to string. I want to modify this system and refer to localization terms instead of strings, but keep this dynamic of creation. Is this possible? (I dont fount api documentation)
11 years 4 months ago #844 by Frank
Replied by Frank on topic add/remove terms through code
In your editor code you can use:
var languageSource = LocalizationManager.Sources[0];
TermData data = languageSource.AddTerm("My Term", eTermType.Text);
Then fill the content of data with the new term translations.
You can also use
languageSource.RemoveTerm( term )
11 years 4 months ago #847 by Deadcow
This is exactly what I wanted, thanks
Time to create page: 0.172 seconds
