Feature implementation : Parse terms from scripts
11 years 4 months ago - 11 years 4 months ago #819 by tacticsofttech
One of the things that were missing for me in the plugin was the ability to autogenerate terms that are only referenced in code.
IE if a script does
ScriptLocalization.Get("My Term")
it would add "My Term" to the term list.
I implemented it as part of the Tools->Parse window, attaching the implementation below.
Would be happy if it could go into the main branch so I won't have to reapply the patch each time I update the version.
If there are any notes regarding this code feel free to ask.
Awesome package btw :)
Last edit: 11 years 4 months ago by tacticsofttech.
11 years 4 months ago #821 by Frank
Thanks for the contribution!
I plan to extend the Script tool to also list ALL the literal strings in your code. Not only the ones used on the ScriptLocalization.Get(x).
Once listed, the developer could select the ones that should be baked.
That should be able to detect things like label.Text = "Play".
However, while I finish the things with higher priority, that contribution is very welcome. I will test it a bit and include it for the next release.
Thanks a lot!
