Scrolling in Inspector for long terms
11 years 4 months ago #814 by Livealot
I have 12 languages in my game. Some of my "terms" are actually help pages. Think of multiple bullets or paragraphs that explain "How to.." for example. As a result, when I expand the "term" it's quite long vertically. When I go to scroll down in the inspector, however, it jumps from the expanded term to the rest of the list of collapsed terms. The net impact is that I can not navigate to or edit terms in the languages at the bottom of the list for each of these vertically challenged terms.
I'm using Unity 4.6.6p1 and i2 version 2.4.2f1
Hope that helps. Thanks, JJ
11 years 4 months ago #815 by Frank
That issue was fixed in one of the last versions.
Just to be sure I double checked that version 2.4.5 (the one in the assetstore) doesn't have the issue.
I created 20 languages, and a few terms. And I was able to add big texts to each of the languages.
If after upgrading to the newest version, you still see a similar issue please let me know.
The following user(s) said Thank You: Livealot
11 years 4 months ago #824 by Livealot
I can confirm that the latest update did indeed fix the scrolling issue.
Time to create page: 0.134 seconds
