Error after updating to Unity 5.1.0
11 years 4 months ago - 11 years 4 months ago #811 by tman1978
I have TextMeshPro (0.1.5 B1.5) installed and I'm getting the following error after updating to Unity 5.1.0:
Assets/I2/Localization/Scripts/Targets/LocalizeTextMeshPro.cs(11,23): error CS0234: The type or namespace name `TextMeshProUGUI' does not exist in the namespace `TMPro'. Are you missing an assembly reference?
Any ideas on how to resolve?
Last edit: 11 years 4 months ago by tman1978.
11 years 4 months ago #812 by Frank
I just downloaded TMPro 0.1.5 Beta 1.5 and tested on Unity 5.0.1p2
I was unable to reproduce that error. TMPro is still showing the TextMeshProUGUI class for me and I'm not getting any error.
Can you try reinstalling TMPro?
Also, have you moved I2L to the Plugins folder? If you moved it, it may not be able to find the TMPro classes.
Another thing you could try: Remove the TextMeshPro and TMProBeta defines in the Build Settings.
That will comment that code and avoid compilations errors. Once the code compiles again, Add the defines again, or execute the menu:
Tools\I2 Localization\Enable Plugins\Force detection
11 years 4 months ago - 11 years 4 months ago #813 by tman1978
Never mind, user error.
Last edit: 11 years 4 months ago by tman1978. Reason: Updated info
