How to localize a changing text
11 years 4 months ago #684
by j3d
How to localize a changing text was created by j3d
I apologize if I missed this in the tutorial, but according to this:
inter-illusion.com/tools/i2-localization/how-to-localize
, it seems that the only way to localize a text is to add the localize script to your object and make sure that the text is in the main source.
Here is what I did: I added the term "run fast" to the source, and then I added the localize script to the guitext. The twist is that the text starts out with the text "don't run", and then later it will change to run fast, which is the text that I want to translate. I wish there was a line of code that would just localize every single guitext that I display but for now this is my issue.
11 years 4 months ago #685
Replied by Frank on topic How to localize a changing text
If what you need its to change the term at runtime, you could call SetTerm.
Here is an example:
www.inter-illusion.com/forum/i2-localiza...a-localised-text#676
Basically, what you need to do is add both "don't run" and "run fast" to the language source and setup the translation of them for each language.
Then, instead of doing:
you should do:
That will change the term and will update the label's text automatically.
Here is an example:
myText.text = "run fast";you should do:
myText.GetComponent<Localize>().SetTerm("run fast", null); That will change the term and will update the label's text automatically.
11 years 4 months ago #686
by j3d
Replied by j3d on topic How to localize a changing text
Okay seems simple, but when I use that particular line there is a minor problem. It says that the namespace Localize has not been found, so I looked at the Localize script and saw it had the namespace I2.Loc but when I used that, it says that it is looking for a type.
11 years 4 months ago - 11 years 4 months ago #687
Hi
To avoid naming conflicts with other plugins, All classes in the I2L plugin are in the I2.Loc namespace.
You can add the namespace at the top of the file where you are accessing the Localize component:
All the example scripts use that way.
The other way is to use I2.Loc.Localize instead of Localize
BTW, are you using JavaScript or C#? Because in JavaScript the compilation order could make some classes inaccessible if the I2L is not moved into the Plugins folder.
using I2.Loc;All the example scripts use that way.
myText.GetComponent<I2.Loc.Localize>().SetTerm("run fast", null); BTW, are you using JavaScript or C#? Because in JavaScript the compilation order could make some classes inaccessible if the I2L is not moved into the Plugins folder.
Last edit: 11 years 4 months ago by Frank.
