Execution of authentication request returned..404
- haikugames
11 years 5 months ago #667
by haikugames
Execution of authentication request returned..404 was created by haikugames
I just got an issue with I2 Localization where it says "Execution of authentication request returned unexpected result 404". I believe this is related to Oath 1.0 not being supported anymore. See the issue here.
code.google.com/p/google-apps-script-iss...ssues/detail?id=5101
Obviously this is a major blocker for us!
Is there any way to fix this?
11 years 5 months ago #668
Replied by Frank on topic Execution of authentication request returned..404
Can you describe me how you got that error.
The plugin doesn't authenticate directly with google so you shouldn't receive that error. To handle the communication with google, the plugin uses a WebService that its installed in your google drive.
The only way I could foresee of getting that error its if you installed the webService but didn't authorized it.
Can you please, check that you have installed the latest version of the plugin (2.4.5) and that the web service is installed. Also, remember you have to follow the installation steps to authenticate the WebService.
- haikugames
11 years 5 months ago #670
by haikugames
Replied by haikugames on topic Execution of authentication request returned..404
I had a previous version of the plugin (2.2 I believe), so I think that is why I have the error. It does not use the WebService strategy. (It was working for the last 3 months, but just stopped working today.)
I see 2.4.5 f3 on the Asset Store. I try to download and update but it turns out that the language sources still has the old Google spreadsheet import. It could be an issue with updating the app on my side. I am also on Unity 4.6.3 so I'm not sure if that is the root of the problem. I sent you an email with my invoice to access the early versions of the build, and I hope that will solve this problem.
Thanks for the quick response!
11 years 5 months ago #672
Yes, version 2.2 used the old approach which I later changed to the webService version as Google started deprecating those methods.
To convert the spreadsheets from version 2.2 to version 2.4.5, you should open the spreadsheet in your google drive and export it as a CSV file.
Then, after you install version 2.4.5, just import the CSV into your language source and export it google.
That will generate the updated spreadsheet (type and desc will be shown as notes).
Please, note that to upgrade the plugin, you should delete the I2 folder and then import the new version!
Hope that helps!
BTW, I just send you an invite to the beta group!
Hope that helps!
- haikugames
11 years 5 months ago #673
by haikugames
Great - I'm happy to report I got it all working by upgrading and using the web service. Thanks for the support!
Time to create page: 0.185 seconds
