Renaming Terms
11 years 4 months ago #642 by mcmorry
Renaming Terms was created by mcmorry
When I add the Localization component to an object with a long text, the suggested auto created term is also very long.
After that I created it I can't find a way to rename it. So the only way I found is to go back to the I2Languages prefab, create manually a new term and go back to the object to choose it from the list.
Would not be much faster to have an input in the Localization component to type in a custom term name in case the default one is not good?
Or there is a different way that I'm missing?
11 years 4 months ago - 11 years 4 months ago #643 by Frank
Replied by Frank on topic Renaming Terms
On the localize component, you can click on the arrow next to "Term" and it will unfold a section for you to create custom terms or rename them.
Hope that helps
Attachment key.jpg not found
Last edit: 11 years 4 months ago by Frank.
11 years 4 months ago #645 by mcmorry
Replied by mcmorry on topic Renaming Terms
Ah yes I was blind!
I took that input only for a search box. I didn't see the buttons on the right.
Also I was trying to rename the terms from the Language Source, and I think that there is not possible.
By the way there is a problem in the search box of terms of the Language Source. As soon as I type one letter it loses the focus. I'm on OSX.
Time to create page: 0.311 seconds
