Fix: Compile Error When Debugging Unity With VS
11 years 7 months ago #607 by JAC
When trying to debug the Unity project with Visual Studio (we're using 2015 CTP) there's a compile error in UpgradeManager.cs
It fails on line 13 on:
EditorApplication.update += CheckPlugins;
because the type signature on:
public static void CheckPlugins( bool bForce = false )
does not exactly match the type signature of the editor update callback:
public delegate void CallbackFunction();
This compiles fine in Unity because the mono compiler in Unity will happily use the compatible signature, but not VS.
For me I fixed by replacing with:
EditorApplication.update += OnEditorUpdate;
public static void OnEditorUpdate()
    EditorApplication.update -= OnEditorUpdate;
    CheckPlugins(false);
public static void CheckPlugins(bool bForce)
	EnablePlugins(bForce);
	CreateLanguageSources();
	CreateScriptLocalization();
So that the editor callback uses the exactly matching signature. It compiles and will debug in VS fine then.
Submitting in case you may want to push a similar change.
11 years 7 months ago #608 by Frank
A similar fix for this issue is found here:
inter-illusion.com/forum/i2-localization...rror-in-2-4-4-f1#554
Also, this fix is included in version 2.4.5 which is now available for download in the AssetStore.
11 years 7 months ago #611 by Frank
Ahrrgggg, I double checked the assetstore and is still showing version 2.4.4 f1.
I already received an email from unity that 2.4.5 was approved, but I guess it still hasn't refreshed the store.
So I guess we will have to wait a couple hours for the new version should be available for download.
11 years 7 months ago - 11 years 7 months ago #612 by JAC
Looks like it's up now. Just downloaded the update. Thanks/Sorry Frank! My bad for not seeing the other post.
Last edit: 11 years 7 months ago by JAC.
Time to create page: 0.406 seconds
