Initialization Issues & CSV Import With Semicolons
11 years 6 months ago - 11 years 6 months ago #591 by JAC
Hey Frank,
Couple more small issues for you.
When you try to import a CSV using semicolons as a separator it fails. This is unfortunate because OpenOffice Calc defaults to using semicolons as a CSV seperator, and most of our office uses OpenOffice Calc (Shame, I know). If I find and replace in the file and replace the semicolons with commas it works. I could send you an example file if you need, but all you need to do is replace comas with semicolons in a working CSV.
Also if you import replace and it fails to import, your existing terms are wiped out. Would be nice if a failed import just left your terms as is, and replaced the lists/dictionaries after it succeed.
Also If you have a button with a SetLanguage component before any Localize components appear in a scene, LocalizationManager won't be initialized when you click the button (we had some set language buttons on an initial scene). When that happens LocalizationManager won't have any supported languages loaded yet, so LocalizationManager.HasLanguage will return false and the selected language won't be applied.
It looks like LocalizationManager.InitializeIfNeeded() needs to be called for this to happen, but that's private and only called in the getter for CurrentLanguage and CurrentLanguageCode (which a Localize would trigger indirectly).
It seems like the better solution would be for HasLanguage calling InitializeIfNeeded(), but for now I added a check on current language to trigger that indirectly before calling HasLanguage
// getting current language triggers initialization
var curr = LocalizationManager.CurrentLanguage;
if(_Language != curr && LocalizationManager.HasLanguage(_Language))
	LocalizationManager.CurrentLanguage = _Language;
Jovanni
Last edit: 11 years 6 months ago by JAC.
11 years 6 months ago #593 by Frank
Hi, I'm please to announce that version 2.4.5 adds support for different CSV separators. (Comma, Semicolon, Tab)!
Attachment CSVseparator.jpg not found
That's also implemented on 2.4.5 :)
Added as well B)
Hope that helps
11 years 6 months ago #594 by JAC
I love you Frank.
But seriously, thanks again. Great support.
