i2Localization Example fails for NGUI 3.8.0
- KasparLund
11 years 7 months ago #545
by KasparLund
i2Localization Example fails for NGUI 3.8.0 was created by KasparLund
NullReferenceException: Object reference not set to an instance of an object
I2.Loc.Localize.DoLocalize_UISprite (System.String MainTranslation, System.String SecondaryTranslation) (at Assets/I2/Localization/Scripts/Targets/LocalizeNGUI.cs:103)
I2.Loc.Localize.OnLocalize () (at Assets/I2/Localization/Scripts/Localize.cs:146)
I2.Loc.LocalizationManager.LocalizeAll () (at Assets/I2/Localization/Scripts/LocalizationManager.cs:151)
I2.Loc.LocalizationManager.SetLanguageAndCode (System.String LanguageName, System.String LanguageCode, Boolean RememberLanguage) (at Assets/I2/Localization/Scripts/LocalizationManager.cs:61)
I2.Loc.LocalizationManager.set_CurrentLanguage (System.String value) (at Assets/I2/Localization/Scripts/LocalizationManager.cs:20)
I2.Loc.LanguagePopup.OnValueChange () (at Assets/I2/Localization/Examples/Targets/NGUI/Scripts/LanguagePopup.cs:25)
EventDelegate.Execute () (at Assets/NGUI/Scripts/Internal/EventDelegate.cs:476)
EventDelegate.Execute (System.Collections.Generic.List`1 list) (at Assets/NGUI/Scripts/Internal/EventDelegate.cs:644)
UIPopupList.TriggerCallbacks () (at Assets/NGUI/Scripts/Interaction/UIPopupList.cs:341)
UIPopupList.set_value (System.String value) (at Assets/NGUI/Scripts/Interaction/UIPopupList.cs:239)
I2.Loc.LanguagePopup.Start () (at Assets/I2/Localization/Examples/Targets/NGUI/Scripts/LanguagePopup.cs:20)
11 years 7 months ago #546
Replied by Frank on topic i2Localization Example fails for NGUI 3.8.0
A few versions ago NGUI changed their example scenes and its atlases. That made the NGUI example scene of the I2 Localization to loose the references to those atlases.
That was corrected on version 2.4.4f1 which is now available on the store. I just double checked by importing NGUI 3.8.0 and I2 Localization 2.4.4f1 directly from the store in an empty project and its working fine for me.
Can you please update the I2 Localization and if you still find issues with the example scene, please, let me know.
Also, are you using Unity 5 or Unity 4?
The following user(s) said Thank You: KasparLund
- KasparLund
11 years 7 months ago #547
by KasparLund
Replied by KasparLund on topic i2Localization Example fails for NGUI 3.8.0
Thanks i should have checked for updates before rasing the issue.
it works now
it works now
11 years 7 months ago #548
Awesome!
Another good news is that version 2.4.4 introduces a plugin manager (Tools\I2 Localization\About),
That will automatically notify you whenever a new version is released (either in the AssetStore or in the beta group).
Also it has links to useful information and videos.
Hope you find it useful,
Time to create page: 0.179 seconds
