Is there a way to add supported UI component?
5 years 1 month ago #4376 by morphus
I'm using Doozy UI which link to a TextMesh Pro to set Text.
Is there a way to add support through code for new components?
If so any guidance on which file to start with?
Thank you
5 years 1 month ago #4377 by Frank
Adding support for new components is quite easy,
You just need to create a class that inherits from LocalizeTarget and implement the corresponding methods.
Most of the time the implementation is quite similar to other existing components, so it will be almost a copy/paste from one of the other targets in the plugin.
For example: LocalizeTarget_UnityStandard_TextMesh or LocalizeTarget_UnityUI_Text
