Bug: AllowLocalizedParameters doesn't work when using fallbacks
5 years 5 months ago #4278 by UltraRat
When applying a LocParam if you never unload used languages and attempt to use a term that has a fallback translation, the param will be blank, rather than the translation of the param in the fallback language.
This seems to be due to LocalizationManager_Parameters.cs's ApplyLocalizationParams checking for
result = termData.GetTranslation(idx);
rather than
result = source.GetTranslation(termData.Term);
5 years 5 months ago #4288 by Frank
Thanks for reporting this issue, will add a fix right away!
