- Forum
- Plugins
- I2 Localization
- Is it possible to localize info in the config file without custome code?
5 years 6 months ago #4275
by YevgenG
Hello, dear L2 developers! Thanks a lot for the pack! I'm extremely sattisfied by using it
Though I have one question. I have a bunch of texts in the config files like these. Is it possible to localize texts in them with L2 localiztion without using custom code? Or I will need to add some functionalty to the asset to translate texts in them?
5 years 6 months ago #4289
Replied by Frank on topic Is it possible to localize info in the config file without custome code?
If I understand you correctly, you have some ScriptableObject assets with strings in them, and you want to localize them.
That's easy to do using LocalizedStrings.
inter-illusion.com/assets/I2Localization...ocalizedStrings.html
Then only change you have to do is to replace all fields of type string by LocalizedString in those ScriptableObject's scripts.
That will allow you to specify a term for each of those strings so that when you retrieve their value it gets the translation to the current language.
Hope that helps
Hope that helps
- Forum
- Plugins
- I2 Localization
