A question about plugin(RTL Related)
11 years 7 months ago - 11 years 7 months ago #506 by ripsoul
Hey there,
I am using a free plugin which handles rtl and persian language. But it has some bugs in it so i decided to buy your plugin.
After some research, i encountered to a post which you explain manual fix in script( ArabicSupport.ArabicFixer.Fix() )
I am wondering are you using that plugin to handle RTL because that function call is exactly same with the one i was using.
Thanks in advance.
Last edit: 11 years 7 months ago by ripsoul.
11 years 7 months ago #507 by Frank
You are correct. Internally the plugin uses the "Arabic Support for Unity" (with permission from the author :-) )
I'm about to refactor how the plugin handles the RTL languages to add support for paragraphs. Do you mind explaining which are the bugs you found in the "Arabic Support for Unity". Maybe I could add a fix on top of it.
The following user(s) said Thank You: ripsoul
11 years 7 months ago #509 by ripsoul
Hey!
Thanks for your reply.
I got problem with letters " ک & ی ".
For example in the word arcade instead of آرکید i got آرک‌ی‌د ( i used spaces to show the problem )
