NGUI Label with dynamic term
11 years 8 months ago - 11 years 8 months ago #498 by StKiller
I have a button which has action depending on context. So, from code, I update button's caption to either "one", "two" or "three".
I have these terms defined in the localization source and there is attached an localization component to the button's label.
The problem is that the localization is not always updated when the label 'text' field is updated. Can I force it to refresh the localization, somehow?
Thank you in advance.
**Update**
I started to use api for in-code localization and removed the localization component from the label itself. Now it works fine.
Last edit: 11 years 8 months ago by StKiller.
11 years 8 months ago #499 by Frank
Replied by Frank on topic NGUI Label with dynamic term
The Localize component takes the Label's text only when its enabled for the first time, if it doesn't have a term.
To change the localized term at runtime, you need to call the function SetTerm of the localize component:
// Instead of
// label.text = "one";
// call:
label.GetComponent<Localize>().SetTerm("one", null);
Calling the SetTerm will change the term that is used and will update the label's text with the translation.
Time to create page: 0.231 seconds
