Marking language as default - Modification
6 years 1 month ago #4167 by frantasad
Hello, in our project we implemented to your asset some small modifications that allow marking language as a "default language".
Right now you just have 2 options, that is use device language or first language in the list, we wanted a 3rd option - use device language if its marked as default, otherwise first language in the list.
We wanted that because when we dont have that good translation to all other languages and we would still like to allow users to select it from the menu, but not let the game to pick it automaticly.
Would you consider to include this modification to your asset ?
I attached my modified codes if you would like to see.
File Attachment:
File Name: Localizati...0-04.zip
File Size:305 KB
6 years 1 month ago #4169 by Frank
That's an interesting feature. Will check the modifications and update the plugin to support it.
Time to create page: 0.120 seconds
