[Solved] LocalizedString with Parameters
6 years 5 months ago - 6 years 5 months ago #4111
by impbox
[Solved] LocalizedString with Parameters was created by impbox
Hi, Is it possible to pass parameters when translating a LocalizedString?
eg. something equivalent to:
LocalizedString foo = "Go To {[Destination]}";
string bar = foo.ToString(("Destination", "test"));
Last edit: 6 years 5 months ago by impbox.
6 years 5 months ago #4112
Replied by Frank on topic [Solved] LocalizedString with Parameters
There is no overload ToString method, but you can apply the parameters by doing:
or if you only need to change 1 parameter:
That's the way if you are setting the parameter's value in the function.
But if the parameters are global, then just uncheck the DontLocalizeParameters in the LocalizedString inspector and it will try finding the parameters in the GlobalParameters without having you to call ApplyLocalizationParams.
string bar = foo;
LocalizationManager.ApplyLocalizationParams(ref bar, new Dictionary<string, object>{{"Destination", "test"}});or if you only need to change 1 parameter:
LocalizationManager.ApplyLocalizationParams(ref translation, (s)=>"test");That's the way if you are setting the parameter's value in the function.
6 years 5 months ago #4113
by impbox
Replied by impbox on topic [Solved] LocalizedString with Parameters
Awesome! Thanks very much Frank!
