Localization in scripts
6 years 8 months ago #4063 by bob
Localization in scripts was created by bob
Hello
I'm new to this tool and I'm trying to figure out how use it best with the scripts I already have.
I have this Dialog script
using System.Collections;
using UnityEngine;
[System.Serializable]
public class Dialogue
    public string name;
    [TextArea(3, 10)]
    public string[] sentences;
I access it from this and send it to my dialog manager.
using UnityEngine.Events;
using UnityEngine;
public class DialogueTrigger : MonoBehaviour
    public Dialogue dialogue;
    public DialogueManager DM;
    public bool Ended = false;
    public UnityEvent m_MyEventStart;
    public  UnityEvent m_MyEvent;
    public bool Use2ndBox = false;
    private void Start()
        DM = FindObjectOfType<DialogueManager>();
    public void TriggerDialogue()
        m_MyEventStart.Invoke();
        DM.StartDialogue(dialogue, this, Use2ndBox);
    public void TriggerEvents()
        m_MyEvent.Invoke();
Each Prefab in scenes that have the DialogTrigger has different text.
Hope you can help or point me in the right direction.
Bob
6 years 8 months ago #4064 by Frank
Replied by Frank on topic Localization in scripts
The easiest way is to replace string by LocalizedString.
LocalizedString works like a string, but when you assign it, you assign the Term Name, and when you read its value it returns the translation to the current language.
inter-illusion.com/assets/I2Localization...ocalizedStrings.html
LocalizedString locString = "Term2"; LocalizationManager.CurrentLanguage = "English"; string translation = locString; // returns the translation of Term2 to English (e.g. 'This is an example') LocalizationManager.CurrentLanguage = "Spanish"; string translation = locString; // returns the translation of Term2 to Spanish (e.g. 'Este es un ejemplo') [/code Their inspector is also shown as a popup to select the term. Hope that helps, Frank[code]
[/code
The following user(s) said Thank You: bob
6 years 8 months ago - 6 years 8 months ago #4065 by bob
Replied by bob on topic Localization in scripts
Works like a charm! thank you for the quick reply
Last edit: 6 years 8 months ago by bob.
Time to create page: 0.194 seconds
