Is there a Term Limit?
6 years 9 months ago #4035 by jimProg
I wanted to ask if there is a Term limit for Unity. For example 1000 terms.
The issue that I have is when I try to select the Main Term on the Localize component in the inspector, <none> and <inferred from text> options are missing. I also get the following warnings:
Failed to ad separator
Failed to insert item. Name: <inferred from text>, Command: 1172
Failed to insert item. Name: <none>, Command: 1173
Unable to insert menu item into submenu since index exceeded limit of 1000, item's parent:Assets
That is happening because I have too many terms (1150) or the issue is something else?
I use Unity 2018.3.13f1 and I2 Localization 2.8.12 f1
Thanks in advance
6 years 9 months ago #4036 by Frank
Replied by Frank on topic Is there a Term Limit?
I2 Localization code doesn't have any constraint in the number of terms, and in previous stress tests I had >500K terms.
But Unity has been changing the inspector GUI code, so I'm not sure if they have added a constraint to how many items can dropdown have.
Will test as soon as I get back!
Thanks for reporting this.
The following user(s) said Thank You: jimProg
6 years 9 months ago #4037 by jimProg
Replied by jimProg on topic Is there a Term Limit?
Yes it seems to be a limit in Unity GUI code considering the dropdown items. Found a similar issue when a project has more than a 1000 scripts that inherit from MonoBehavior. ( Issue Tracker )
One solution is to separate the terms into categories (better late than never :oops: ) and not use exclusively the “Default” category.
Thank you very much for your answer!
Time to create page: 0.200 seconds
