`System.IO.File' does not contain a definition....
11 years 8 months ago - 11 years 8 months ago #454
by tman1978
`System.IO.File' does not contain a definition.... was created by tman1978
I installed 2.4.0 yesterday but found that I could no longer do a web build. I was previously using 2.3.0, which worked fine for web deployments. Hoping that it would resolve my web build problem, I upgraded to 2.4.0 f2 from the Asset Store. However, that made things worst. Now my code won't even build in the editor. It failed with the following error:
Please help.
Unity 4.6.1
I2 2.4.0 f2
Win 8.1
WebPlayer
Assets/I2/Localization/Scripts/LocalizationReader.cs(89,55): error CS0117: `System.IO.File' does not contain a definition for `ReadAllText'Please help.
Unity 4.6.1
I2 2.4.0 f2
Win 8.1
WebPlayer
Last edit: 11 years 8 months ago by tman1978.
11 years 8 months ago - 11 years 8 months ago #455
Replied by Frank on topic `System.IO.File' does not contain a definition....
Thanks for reporting that issue. It is fixed on 2.4.1 a2 that can be downloaded from the I2 Community.
Nonetheless, I'm attaching the LocalizationReader.cs with the updated code. By replacing the file that v2.4.0 installs by this one, it will fix the issue.
Thank,
Thank,
Attachment LocalizationReader.zip not found
Last edit: 11 years 8 months ago by Frank.
11 years 8 months ago - 11 years 8 months ago #456
by tman1978
Replied by tman1978 on topic `System.IO.File' does not contain a definition....
The file you provided enabled me to get past the build error in the web player. However, it seems to have introduced a new problem. My "On Localize Call" functions no longer get called.
EDIT:
They no longer get called in the editor but they do get called if I build and run in a web browser.
EDIT:
11 years 8 months ago #457
That its a regression introduced by the new feature that allows you to click on the languages to see if they fit in the label
(i.e. On The localize component, if you click on the translations, the label is changed into that text, so that by clicking one at a time you see how all the languages fit in your interface)
You can solve that by using the Attached file, on downloading version 2.4.1 a3
Attachment EventCallback.zip not found
Time to create page: 0.198 seconds
