Imported spreadsheet does not get saved
11 years 8 months ago #446
by tman1978
Imported spreadsheet does not get saved was created by tman1978
Hi folks,
I set up my project to use the Google spreadsheet feature. I added my localizations to the Google spreadsheet then did an import (replace). The localizations showed up in the editor and when I ran my game all of my localizations showed up correctly. However, when I closed then reopened Unity, all of my imported localizations were gone. They had not been saved in the localization prefab. I did the import again and observed the same behavior after I closed and reopened Unity. I was able to get around the problem by Importing from Google, then exporting to CSV file, then importing the CSV file. Only then did my translations get saved to the localization prefab.
Has anyone seen this issue before? This is my first time using the Google spreadsheet.
Unity 4.6.1
I2 2.3.0
Windows 8.1
Thanks.
Unity 4.6.1
I2 2.3.0
Windows 8.1
Thanks.
11 years 8 months ago #447
Replied by Frank on topic Imported spreadsheet does not get saved
You should install 2.4.0. There were several fixes for that and related issues on 2.3.1 and 2.3.2. Finally on 2.4.0 part of that section was rewritten.
11 years 8 months ago #448
by tman1978
Replied by tman1978 on topic Imported spreadsheet does not get saved
I haven't tried 2.4.0 as yet. I'm stuck on 2.3.0 because there was a problem when I tried to use 2.3.2 with the current released version of TextMesh Pro. Would you happen to know off hand if 2.4.0 works with the currently released version of TextMesh Pro (0.1.44)?
11 years 8 months ago #449
The current version supports the TextMeshPro v0.1.46 B3.3. But if you are using the official 0.1.44 and unity 4.6 or higher you will get compile errors, as the latest TextMeshPro adds TextMeshProUGUI
I will add a condition in the next version to allow disabling localizing that object if you are not using the v0.1.46
But you could install 2.4.0 and make the following changes to make it compile fine:
I2\Localization\Scripts\Targets\LocalizeTextMeshPro.cs
Modify the beggining to make it look like:
That should fix the compile errors.
I will correct this for next version and add a conditional to automatically detect if you are using the official or the beta version of TextMeshPro
using UnityEngine;
using System.Collections;
// ADD THIS -----------------
namespace TMPro
class TextMeshProUGUI : TextMeshPro
namespace I2.Loc
{That should fix the compile errors.
11 years 8 months ago - 11 years 8 months ago #450
by tman1978
I upgraded to 2.4.0 and made the change to LocalizeTextMeshPro.cs that you suggested but it resulted in a new error:
EDIT:
I've gotten past the errors by upgrading to text mesh pro 0.1.46 B3.3.
Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Tools_NoLocalized.cs(83,31): error CS0234: The type or namespace name `TextMeshProUGUI' does not exist in the namespace `TMPro'. Are you missing an assembly reference?EDIT:
Last edit: 11 years 8 months ago by tman1978.
11 years 8 months ago #451
I just updated the plugin to support TextMeshPro v0.1.44 and 0.1.46 B3.3
That fix is included in v2.4.1a1 which can be downloaded from the I2 community.
Time to create page: 0.213 seconds
