iOS build on 2.4.0 fail
11 years 8 months ago #444 by roady
Just updated the plugin to 2.4.0, running Unity 4.6.1.
Get error when exporting to device.
I've deleted the plugin directory and installed the plugin.
Assets/I2/Common/EditorTools.cs(1,7): error CS0246: The type or namespace name `UnityEditor' could not be found. Are you missing a using directive or an assembly reference?
Assets/I2/Common/EditorTools.cs(152,54): error CS0246: The type or namespace name `SerializedProperty' could not be found. Are you missing a using directive or an assembly reference?
Assets/I2/Common/EditorTools.cs(232,51): error CS0246: The type or namespace name `SerializedProperty' could not be found. Are you missing a using directive or an assembly reference?
Error building Player because scripts had compiler errors
11 years 8 months ago - 11 years 8 months ago #445 by Frank
Replied by Frank on topic iOS build on 2.4.0 fail
Sorry for that issue. That was fixed on 2.4.0f2 but that version is still waiting for review on the AssetStore.
However, you could download 2.4.0f2 from the I2 Community which include that and a few other fixes.
Another way to make that work is more move that file into the folder: Assets/I2/Common/Editor/
Please, be aware that if you get the latest version, you will need to delete the I2 folder again to avoid duplicated files as some files changed their location.
Last edit: 11 years 8 months ago by Frank.
11 years 8 months ago #452 by roady
Replied by roady on topic iOS build on 2.4.0 fail
Now I installed 2.4.0f2 from AssetStore.
Now exporting to device works again.
BUT:
When using Spreadsheet -> Import -> replace with an earlier exported csv unity crashes instantly.
Tried to delete the I2 folder and imported plugin.
attached my csv file.
11 years 8 months ago #453 by Frank
In Mac there is a Unity bug that makes the Open File Dialog crash when previewing csv files.
I contacted Unity and reported the bug, but still waiting for it to be solved.
Here you can find a workaround
inter-illusion.com/forum/i2-localization...mport-local-csv-file
Just to double check I exported/imported a csv in windows and it works fine, the same for a mac with an older OS.
11 years 8 months ago - 11 years 8 months ago #461 by roady
Issue seems to be fixed in Unity 4.6.2
UPDATE
Seemed to work only once. Now it doesn't work anymore even after computer restarts. :angry:
Last edit: 11 years 8 months ago by roady.
Time to create page: 0.184 seconds
