Create terms from script
- sewerhrehorowicz
7 years 2 months ago #3908
by sewerhrehorowicz
Create terms from script was created by sewerhrehorowicz
How can I create terms from c#?
thanks in advance
thanks in advance
7 years 2 months ago #3909
Replied by Frank on topic Create terms from script
Here are a few links that explains in more detail how to add terms:
inter-illusion.com/forum/i2-localization...s-via-a-scripts#2799
inter-illusion.com/forum/i2-localization...m-editor-script#3296
Basically, you just find the LocalizationSource and use the AddTerm(xx). And then call UpdateDictionary to update the cache.
LocalizationManager.Sources[0] its the I2Languages.prefab
TermData termData = LocalizationManager.Sources[0].AddTerm("My New Term");
termData.Languages[0] = "This is an Example";
termData.Languages[1] = "Esto es un ejemplo";
// after adding al the terms
LocalizationManager.Sources[0].UpdateDictionary();LocalizationManager.Sources[0] its the I2Languages.prefab
- sewerhrehorowicz
7 years 2 months ago #3913
by sewerhrehorowicz
Replied by sewerhrehorowicz on topic Create terms from script
In Editor, this will cause out of range exception, and first you need to call this:Then it will work.
Guys please fix website. Submit button is cut off, there is no scrollbar and I have to hack styles in developer console to reply.
LocalizationManager.InitializeIfNeeded();Guys please fix website. Submit button is cut off, there is no scrollbar and I have to hack styles in developer console to reply.
