- Forum
- Plugins
- I2 Localization
- TextMesh Pro: Using <font="fontAssetName">-tags with different font per language
- paulsamson
7 years 3 months ago #3889
by paulsamson
TextMesh Pro: Using <font="fontAssetName">-tags with different font per language was created by paulsamson
Thanks for a great plugin!
I'm using it with TextMesh Pro - and in TextMesh Pro I use the <font="fontAssetName">-tags to change fonts in the middle of a text.
However now I'm starting to localize to non-latin langs, so I need different fonts for those langs - and using secondary terms for that. But how does I get that to play well with the <font="fontAssetName">-tags?
(Those tags only point to a single font file...)
Thanks in advance!
Thanks in advance!
7 years 3 months ago #3890
Replied by Frank on topic TextMesh Pro: Using <font="fontAssetName">-tags with different font per language
You can use parameters:
inter-illusion.com/assets/I2LocalizationManual/Parameters.html
Basically, just replace your font name with a parameter tag and then have a global parameter manager that returns the correct font depending on the language:
e.g. your text:
'xxxxxx <font="{[Font1]}"> xxxx'
and your manager:
Then, create a term named "Font1" and set the corresponding font for each language
Another alternative if you need even more control is to use callbacks to detect those cases and apply any change you need to the text:
inter-illusion.com/assets/I2LocalizationManual/Callbacks.html
e.g. your text:
and your manager:
public virtual string GetParameterValue( string ParamName )
if (ParamName == "Font1")
return LocalizationManager.GetTranslation("Font1");
return null; // not found is defined null, not ""
}Then, create a term named "Font1" and set the corresponding font for each language
- Forum
- Plugins
- I2 Localization
