Error after updating
7 years 5 months ago #3790 by ellen
Error after updating was created by ellen
I just added I2 to a new project. Only thing I have done before this is importing Textmesh Pro, Cinemachine and Unity IAP. And when adding latest i2 I get this error:
Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Terms_Description.cs(508,40): error CS0117: `I2.Loc.eTermType' does not contain a definition for `TextMeshPFont'
7 years 5 months ago #3792 by Frank
Replied by Frank on topic Error after updating
Most likely you have a compile error in some script in your project and is causing the editor to not access the correct enum values.
My suggestion is to remove 'TextMeshPro' from your script define symbols to disable TextMeshPro integration with I2 Localization.
inter-illusion.com/assets/I2Localization...lizationTargets.html
Check that there is no other compile errors in your project.
Then, reenable the integration by adding TextMeshPro again into the Script define symbols.
Time to create page: 0.168 seconds
