Problems with CSV import
11 years 8 months ago #389
Replied by Frank on topic Problems with CSV import
Duplicated thread,
Check this instead: www.inter-illusion.com/forum/i2-localiza...mport-local-csv-file
- keshav5999
5 years 1 month ago #4374
by keshav5999
Replied by keshav5999 on topic Problems with CSV import
While importing the spreadsheet from google drive, it takes first column as keys, can i change so that it takes fifth column or any column for the keys?
5 years 1 month ago #4379
By default the plugin reads the Key from the first downloaded column. If you need to modify it, you could change the code that searches for that column.
in: Assets/I2/Localization/Scripts/LanguageSource/LanguageSourceData_Import_CSV.cs
function: Import_CSV // this is called from both import CSV and imported from google
these variables define the columns containing the keys, desc and first language:
int LanguagesStartIdx = 1;
int TypeColumnIdx = -1;
int DescColumnIdx = -1;
you will need to comment out the if
if (Tokens.Length>1 && ArrayContains(Tokens[0], ValidColumnName_Key))
which is where those variables are filled out based on the header text, and instead, just manually set the values yourself.
For instance:
int LanguagesStartIdx = 10;
int TypeColumnIdx = 6;
Then in line 125 change the Tokens[0] by the column you want.
Like in:
string sKey = string.IsNullOrEmpty(Category) ? Tokens[5] : string.Concat(Category, "/", Tokens[5]);
That will take the column 6 as the key
For instance:
Like in:
The following user(s) said Thank You: keshav5999
