audio in timelines
- gregdowning
7 years 7 months ago #3597
by gregdowning
audio in timelines was created by gregdowning
I am a new user, just got everything setup and am successfully switching between languages for text mesh pro etc. I am now looking at the localization for the voiceover. All of the voiceover audio are audio clips in a timeline not audio sources. When I select the audio there is no "add component" field for the localization script. Do I have to localize the whole timeline? I would prefer not to have to work out all the timings etc in the timeline twice if there is a way to localize just the audio on the timeline. What is the correct approach here?
7 years 7 months ago #3600
Replied by Frank on topic audio in timelines
Unfortunately, there is currently not a built-in way to localize Timeline track or clips.
But I like the suggestion of doing so, I was going to start adding Timeline support for my other plugin I2 Text Animation, so, as I do so, I will see how can localization can be integrated to the unity timeline clips and do that for I2 Localization.
I will let you know as soon as I have a beta with it.
- gregdowning
7 years 7 months ago #3604
by gregdowning
Replied by gregdowning on topic audio in timelines
Yikes! So am I in trouble for my delivery in April? Do you have a suggested work around?
- gregdowning
7 years 2 months ago #3910
by gregdowning
Hi Frank, I am facing this situation again on another project, is there a beta yet or anything I can do other than forking the project?
