Unity 2018 problems
7 years 8 months ago - 7 years 8 months ago #3534 by Melbot
Unity 2018 problems was created by Melbot
Hello, it seems that it has problems with unity 2018 ...
When a GameObject containing "Localize" component is selected to be edited in the inspector, an error is thrown through console several times ... this one
Copied style is null. Using StyleNotFound instead.
UnityEngine.GUIStyle:.ctor(GUIStyle)
I2.Loc.LocalizationEditor:OnGUI_Keys_Language_SpecializationsBar(TermData) (at Assets/[MelbitsWorldServerClient]/Plugins/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Terms_Description.cs:309)
I2.Loc.LocalizationEditor:OnGUI_Keys_Languages(String, Localize, Boolean) (at Assets/[MelbitsWorldServerClient]/Plugins/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Terms_Description.cs:227)
I2.Loc.LocalizeInspector:OnGUI_PrimaryTerm(Boolean) (at Assets/[MelbitsWorldServerClient]/Plugins/I2/Localization/Scripts/Editor/Inspectors/LocalizeInspector.cs:342)
I2.Loc.LocalizeInspector:OnGUI_Terms() (at Assets/[MelbitsWorldServerClient]/Plugins/I2/Localization/Scripts/Editor/Inspectors/LocalizeInspector.cs:249)
I2.Loc.LocalizeInspector:OnInspectorGUI() (at Assets/[MelbitsWorldServerClient]/Plugins/I2/Localization/Scripts/Editor/Inspectors/LocalizeInspector.cs:153)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
And some fonctionalities are not working properly ... for example, the one i needed, "specialization"
Is there any update or workarraund ?
Thank you
Last edit: 7 years 8 months ago by Melbot.
7 years 8 months ago #3540 by Frank
Replied by Frank on topic Unity 2018 problems
Depending on what version of I2 Localization you are using, there was a fix for the missing style in one of the latest releases.
Said that, I didn't like how it was looking and the way it created a specialization but didn't save it until you made changes, which didn't allow creating several specializations at the same time.
I made a fix for that in v2.8.12b1. It can be downloaded from the beta folder.
7 years 8 months ago #3541 by Melbot
Replied by Melbot on topic Unity 2018 problems
Perfect ... we just updated to v2.8.11 and it seems to be working correctly ... about creating several specializations at once, i'll keep that in mind ...
