Problem with caching from google
7 years 8 months ago #3532
by Euge
Problem with caching from google was created by Euge
I’m using the web service to update the localizations from google and this is my setup:
Auto Update Frequency: Never
Update Synchronization: As Soon As Downloaded
I call the “I2.Loc.LocalizationManager.Sources[0].Import_Google(true, false);” only when I change a flag from my server and it works, but I’m a problem.
At the first app launch the translations are correctly updated from the server.
When I kill and reopen the app I would expect that the translations previously downloaded should be loaded from the cache, but this does not happen.
The translations that shows up are the ones builded in the app and not the ones downloaded from google.
I’m doing something wrong?
7 years 8 months ago - 7 years 8 months ago #3536
Replied by Frank on topic Problem with caching from google
The problem is that the plugin doesn't load the data from the cache if the auto update frequency is NEVER
Assets\I2\Localization\Scripts\Manager\LocalizationManager_Sources.cs
line 74 function AddSource
To solve this issue and update from the cache after you have manually downloaded data, you can do one of this:
- set GoogleUpdateFrequency to LanguageSourceData.eGoogleUpdateFrequency.OnlyOnce
or
manually call Source[0].Import_Google_FromCache() on startup
if (Source.HasGoogleSpreadsheet() && Source.GoogleUpdateFrequency != LanguageSourceData.eGoogleUpdateFrequency.Never)
#if !UNITY_EDITOR
Source.Import_Google_FromCache();
bool justCheck = false;
#elseTo solve this issue and update from the cache after you have manually downloaded data, you can do one of this:
or
Last edit: 7 years 8 months ago by Frank.
