Exception when adding Language dynamically
7 years 8 months ago #3525 by protostarDean
I am creating and adding a language source data at runtime (The strings are downloaded from the web).
In the latest update (2.8.11) I get an exception here:
public void AddLanguage( string LanguageName, string LanguageCode )
			if (GetLanguageIndex(LanguageName, false)>=0)
				return;
			LanguageData Lang = new LanguageData();
				Lang.Name = LanguageName;
				Lang.Code = LanguageCode;
			mLanguages.Add (Lang);
			int NewSize = mLanguages.Count;
			for (int i=0, imax=mTerms.Count; i<imax; ++i)
				Array.Resize(ref mTerms[i].Languages, NewSize);
				Array.Resize(ref mTerms[i].Flags, NewSize);
			#if UNITY_EDITOR
//!!!! ownerObject is null, causing an exception. !!!
				UnityEditor.EditorUtility.SetDirty(this.ownerObject);
			#endif
Works if there is a guard there, but be great if this was fixed.
7 years 8 months ago #3526 by Frank
The LanguageSourceData was always meant to be used within a LanguageSourceAsset or a LanguageSource. But I guess its a valid usage to create that object dynamically and use it directly.
Will made the changes to support it.
7 years 8 months ago #3530 by protostarDean
Awesome! Thanks for that.
I will look out for it in the next update.
7 years 8 months ago #3539 by Frank
I just uploaded v2.8.12b1 to the beta folder that includes a fix for that.
Now all SetDirty calls are safeguarded and you should be able to dynamically create a LanguageSourceData and use it at runtime without having that crash.
Time to create page: 0.181 seconds
