Richtext seems to not work with RTL
7 years 8 months ago #3522
by elusiven
Richtext seems to not work with RTL was created by elusiven
I'm parsing my RTL (Urdu, Arabic) translations from google spreadsheet into the app. As soon though as I apply the I2's RTL fix the richtext does not work, the characters get inverted, like <> to >< etc. In conjunction to this I need to use another tool as well that fixes the text further and overall it makes it problematic to even use rich text with RTL. Is there a fix for this ?
7 years 8 months ago #3538
Replied by Frank on topic Richtext seems to not work with RTL
Thanks for reporting this! The RTL fixer was handling the tags in the format [xxx] but not the <xxx>.
I just included a fix for that into v2.8.12b1 which can be downloaded from the beta folder.
Time to create page: 0.117 seconds
