Does the "Description" actually work for anybody?
7 years 11 months ago #3314
by kylerwk
Does the "Description" actually work for anybody? was created by kylerwk
I'm latest I2 2.8.9 F1 with a google spreadsheet, that is newly setup.
Whenever I tried to add descriptions to terms in Unity, or notes in the google spreadsheet, they always just seem to get lost on the import or export.
Does this feature actually work for anybody?
7 years 11 months ago #3316
Replied by Frank on topic Does the "Description" actually work for anybody?
I tried running all the unit tests regarding this, and they all work as expected.
I also tried, adding a description to a term, then do Export/Replace. And verified that the Google Spreadsheet shows the description as a Note.
Then, if I edit the note and click Import/Replace, the new description is added to the term in Unity.
Is that not working for you?
What Unity version are you using?
Can you list here the steps you are using to reproduce the issue? Maybe I'm missing something in my tests?
