Load translaltions for each language ON DEMAND
- nelsonlarocca
8 years 1 week ago #3272
by nelsonlarocca
Load translaltions for each language ON DEMAND was created by nelsonlarocca
Hi !
Is there any way to load the translations for each language on demand instead of keeping all in the local storage ?
I mean, suppose the language of the device in English and the user switches to French, that would mean loading the French terms from the "cloud" removing the English ones. If the user later decides to switch to a different one, right the same process.
Our app will be translated to several languages so the idea is to optimize storage.
Any help will be appreciated.
Regards,
Nelson
Regards,
Nelson
8 years 1 week ago #3274
Replied by Frank on topic Load translaltions for each language ON DEMAND
If you need to load the translations from the cloud, you can do that by using AssetBundles.
Instead of having all your localization in I2Languages.prefab, create a copy of that prefab for each Language and add them to different bundles.
Then, whenever you switch languages, download the bundle, and instantiate the LanguageSource into the scene. As far as the LanguageSource is enabled, your localize component will be able to use its translations.
Another way, is to create a CSV spreadsheet for each language and store them in your server.
Then, whenever you need to load the new language, just download it and call Import_CSV to add it to the I2Languages.prefab
An example of this can be found at:
inter-illusion.com/assets/I2Localization...portingaCSVfile.html
See the DownloadCSV function.
