Error
8 years 2 months ago #3229 by Shinsuki
Error was created by Shinsuki
I've put I2 Localization in my project and I have this error, anyone know why and how I can retire this ?
Assets/I2/Localization/Scripts/Utils/PersistentStorage.cs(6,25): error CS0101: The namespace `I2.Loc' already contains a definition for `PersistentStorage'
Thanks you very much for you're help and time.
Best regards,
Carlos De Sousa
8 years 1 month ago #3230 by Frank
Replied by Frank on topic Error
The PersistentStorage file was moved to Assets\I2\Localization\Scripts\Configurables
So, it seems that Unity failed to import the package correctly and delete the old file.
To solve this problem, you should
- Delete the I2 folder
- Install I2 Localization again.
That will remove any old file and will compile fine.
forum.unity.com/threads/i2-localization-...page-11#post-3544325
The following user(s) said Thank You: Shinsuki
8 years 1 month ago #3231 by Shinsuki
Replied by Shinsuki on topic Error
Thanks you very much, it's working :)
Best regards,
Carlos
Time to create page: 0.181 seconds
