How to ignore some sheets?
8 years 2 months ago #3162 by JOY
I'd like to ignore some sheets (used for noting purpose) in Google Spreadsheets. How to do that with I2?
Anh
8 years 1 month ago #3173 by Frank
Replied by Frank on topic How to ignore some sheets?
Any sheet whose name starts with ~ is ignored.
Just name your sheets "~SomeColumn" instead of "SomeColumn"
The following user(s) said Thank You: JOY
8 years 1 month ago #3177 by JOY
Replied by JOY on topic How to ignore some sheets?
Thank you. For the column is it starting with "$" ?
8 years 1 month ago #3179 by Frank
Both the column and the sheets can be skipped by adding a ~ as its first character.
When columns have $ as their first character, it means that the language that column represents is disabled.
8 years 1 month ago #3180 by JOY
Thanks. Last question, should I use Description or "~Description" for the description column?
8 years 1 month ago #3181 by Frank
If its a local CSV file, then it should be "Description" and should be the third column. (Term, Type, Description)
If its a Google Spreadsheet, then it doesn't use a column for the description. Instead, it uses a note in the cell with the Term name.
My advice for setting this up is to import the spreadsheet to unity, set the description and export back. That will setup the notes for you.
Time to create page: 0.171 seconds
