How to ignore some sheets?
8 years 3 months ago #3162
by JOY
How to ignore some sheets? was created by JOY
I'd like to ignore some sheets (used for noting purpose) in Google Spreadsheets. How to do that with I2?
Anh
Anh
8 years 2 months ago #3173
Replied by Frank on topic How to ignore some sheets?
Any sheet whose name starts with ~ is ignored.
Just name your sheets "~SomeColumn" instead of "SomeColumn"
The following user(s) said Thank You: JOY
8 years 2 months ago #3177
by JOY
Replied by JOY on topic How to ignore some sheets?
Thank you. For the column is it starting with "$" ?
8 years 2 months ago #3179
Both the column and the sheets can be skipped by adding a ~ as its first character.
When columns have $ as their first character, it means that the language that column represents is disabled.
8 years 2 months ago #3180
by JOY
Thanks. Last question, should I use Description or "~Description" for the description column?
8 years 2 months ago #3181
If its a local CSV file, then it should be "Description" and should be the third column. (Term, Type, Description)
If its a Google Spreadsheet, then it doesn't use a column for the description. Instead, it uses a note in the cell with the Term name.
My advice for setting this up is to import the spreadsheet to unity, set the description and export back. That will setup the notes for you.
Time to create page: 0.249 seconds
